TwinTurbo.NET: Nissan 300ZX forum - Check the fuel pressure reg and damper for leakage
DAYTONAZ
on January 02, 2016 at 10:14 AM
Began as unstable idle for a few days, then
posted by 91z tt
on December 28, 2015 at 02:30 PM
If one of those ruptures you will pump unmetered fuel into the plenum and get the results you have.
Z gurus...need some SERIOUS help, I'm STUMPED
91z tt
07:23:35 12/28/15
Check all your air lines and pipes for
doug8867
10:13:36 12/28/15
Re: Check all your air lines and pipes for
91z tt
13:17:24 12/28/15
Happen while cruising, or mashing the gas? (n/m)
FrozTTy
13:29:57 12/28/15
91z tt
14:30:08 12/28/15
Ok... how is your main engine harness?
FrozTTy
09:02:59 12/29/15
Check the fuel pressure reg and damper for leakage -
DAYTONAZ
10:14:34 01/02/16
Pull the vavuum hoses off check for fuel (n/m)
DAYTONAZ
10:15:17 01/02/16
New FPR and dampner. (n/m)
91z tt
22:55:59 01/02/16
Hmm
Drk93TT
21:47:04 12/28/15
Re: Z gurus...need some SERIOUS help, I'm STUMPED
MaxxAction
19:42:15 12/30/15
Used vacuum diagram from Nick 2009 Stradsport....
91z tt
22:54:46 01/02/16
Re: Used vacuum diagram from Nick 2009 Stradsport....
ThunderZ
07:45:55 01/03/16
Yep...used my boost leak tester. Pressurized to 7
91z tt
08:38:09 01/03/16
Re: Yep...used my boost leak tester. Pressurized to 7
MaxxAction
09:56:43 01/03/16
That's my next step. I'll let you guys know how it works
91z tt
10:52:38 01/03/16
